Factory Keyless Entry (Gen4) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2011, 11:48 AM   #1 (permalink)
Mario Mobile
DM616's Avatar
Gameroom cash: $221100
View DM616's Photo Gallery
I'm just wondering what the distance is supposed to be?
Mine is not even 20 feet <_<. I thought it was supposed to be 50.
I'm fairly sure it's a new battery in the keyfob.
Just curious, but it does get annoying sometimes when I'm walking away and I want to make sure it's locked...but I have to go all the way back and be next to the car.
DM616 is offline   Reply With Quote
Old 07-16-2011, 07:35 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
yeah, after a while i think the contacts loose strength so the wireless signal gets weaker. you can try to pull the remote apart and clean it good, but it might not help
Old 07-16-2011, 08:14 PM   #3 (permalink)
My 98 LE is just about the same 10' ... 20' at the most... seems to be by design. I don't think you will achieve any improvement with a new battery, or cleaning procedure. If you could find the receiving antenna element within the car, you might lengthen the wire or whatever it is, and see if that would help.
I also have a Gen 5 Camry, and the remote key distance is noticeably greater. However, I don't know precisely why. ... more transmitter power, more receiving sensitivity.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 07-16-2011, 08:24 PM   #4 (permalink)
Mario Mobile
DM616's Avatar
Ah so it's not just me. Yah I hate seeing other cars and they can buzz it open like 50 feet away lol.
Maybe it's time to fix this .
I also heard if you hold the fob up to your chin...apparently it increases the distance...haven't tried it yet
EDIT: It works LOL. If you hold the fob up to your chin (opposite of the red led light), it will add like 20 or so feet.
You may look ridiculous while doing it...but it's better than nothing.
I'm going to look into a real way to extending this though.
Old 07-17-2011, 05:32 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
that's pretty normal on either of Toyotas we have haha! two different systems (factory one on V6 and dealer installed Fujitsu-Ten on i4) and the same problem, short distance of a remote ... I replaced batteries in them some time ago and it never got better
I haven't tried using my own skull as a range extender though
Old 07-17-2011, 06:31 PM   #6 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Yeah, the range on older Toyotas are not that good. Mine was so bad I could only be standing next to the car for it to work, but after replacing the battery its at least 40 ft.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 07-17-2011, 06:35 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah, but 40ft is still a joke, come on ... it's like 10 steps away from car and no more reception
Old 07-18-2011, 11:03 AM   #8 (permalink)
View slavie's Photo Gallery
Strange... I have an aftermarket Prestiege alarm on my car, and I can turn it on with ease from well over 50ft. My brothers 2002 Mazda MPV, I turned on the alarm from 120-150ft yesterday, no problem.
I say take apart that remote and change the battery/clean it up inside a bit.
slavie is offline   Reply With Quote
Old 07-18-2011, 11:10 AM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
new battery and cleaning of the remote doesn't help much with those older Toyota factory/dealer systems, it's just how they work
I think 50ft is their max range anyways ...
