I copied this from another thread and was wondering if this would help or is it more for initial warm-up of the engine.
I have tested Ohms and everything is in spec. 21.3 when cool
Used 9 volt battery and IAC closed and opened.
Might have to go to local dealer and have ECM checked out. Car doesn't die but 450-500RPM's is a bit too low for me with A/C on.
[QUOTE=N/A Camry Sleeper;3406518]IT'S FIXED!!!!
Turns out that it IS adjustable as I had suspected by loosening the two small screws and doing some experimenting. First pic is where I started from...looks like it is close to midway between stops:
I first tried to turn it counterclockwise to its full CCW travel so it looked like this:
When I did this idle speed jumped to 2000 RPM and surged between about 1600 and 2000RPM with the computer (I guess) trying to compensate for too fast an idle. So I turned it the opposite way to full clockwise travel, and idle went to 750 RPM on the dot!
If you do the "remove-coolant-lines-to-IAC" mod then you will likely need to turn this adjustment plate FULLY CLOCKWISE for normal idle in colder weather - like so (I just inverted the picture here guys):
HOWEVER, I have no idea how it will idle in the summer months
We shall have to wait and see
