-obx short ram which im about to extend into fender to suck up colder air.
-im about to install 1 level colder denso spark plugs.
-trd supercharger. 3psi@redline
-im about to get obx headers 2.5"
-megan racing cat back. is it 2.5"
-will get aem fic soon
-will get meth injection when i get the aem fic
blown knock sensor. im going to replace the knock sensor in a few weeks. after i replace the knock sensor, im going to make a det can to see if im actually knocking (that caused the knock sensor to blow). if im knocking, im going to lay off the gas pedal until i get the fic and meth injection so i can tune.
if i dont hear detonation, then im going to check the ignition timing to see if its being retarded. if it is, then its due to noise so i'll have to decide if i should relocate, etc so they dont pick up as much noise.
if theres no detonation AND the ecu isn't pulling timing, then i have no idea why the hell the knock sensors blew.
**right now, im looking at fuel upgrade options because people keep telling me that i am running lean and i need to upgrade my fuel system. but i dont see how my fuel system can't support my car because i can get 11:1 afr on WOT even at redline. im pretty sure my fuel system is OK but its my tune thats causing me to run "lean" at high load before it goes into open loop.
**the only weak link i can see in my fuel system right now is the distribution of the two fuel rails causing some cylinders to go lean. so im going to make a custom fuel line from the filter to the rails. but like i said, im still looking at other fuel upgrades cause i want to learn about them and how they can help my car. mainly how i can tell when i actually need those upgrades when i up boost
sorry for such a long post. hope it wasnt too confusing.
thanks,
d
