strange box hanging from intake pipe?
Just got my sister's 2000 Camry CE 4cly back to my place to do various repairs. While poking around in the engine compartment I found a little vacuum valve or sensor or something that looked like it was supposed to be bolted onto something by was just sitting there. I then determined that it was supposed to be bolted to this box near by it, which is also not connected correctly because of a broken mounting bracket. The box has a little pin thing on top that goes through a hole coming off the bottom of the intake pipe, so it hangs from under there. It also used to have a bracket securing it off to the side near the airbox, but that's broken, and then near the top the valve used to bolt on. But, I can't figure out what this box does. It seems to have only one thing connecting to it which is a tube that feeds into the intake pipe after the like from the valve cover and before the throttle body. What is this thing? Is it supposed to have other connections that I'm missing?
