Severe Oil Leak at front cover, most likely source? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2011, 06:50 PM   #1 (permalink)
View LS1Fan's Photo Gallery
Hi all,
I'm new to this site and recently purchased a '94 Camry with the 2.2 engine.
There is a severe oil leak on the front of the engine. Oil is running out from the bottom of the plastic timing cover. Any guesses on what would be leaking this much oil at once?
Cam seal, Crank seal or Oil pump?
I've replaced the front timing cover as it was cracked and also the valve cover gasket.
Thanks in advance!
LS1Fan is offline   Reply With Quote
Old 07-20-2011, 07:23 PM   #2 (permalink)
Gameroom cash: $814501
View zythr's Photo Gallery
Originally Posted by LS1Fan View Post
Hi all,
Thanks in advance!
Seems like you answered your own question.
zythr is offline   Reply With Quote
Old 07-20-2011, 07:30 PM   #3 (permalink)
Let me rephrase:
What would leak this much oil at once, the crank seal or the cam seal or the oil pump?
Thanks!
Old 07-20-2011, 07:41 PM   #4 (permalink)
Let me rephrase:
Thanks!
Could be the crank and/or cam seals. They can leak when the engine is running and also leak residue oil after the engine is shut off.
