Originally Posted by dc_98_cam
With regard to the wheel well noise, get it inspected by a qualified mechanic ... immediately.
I had a steering problem .... constantly drifted off the road ....required considerable force to hold the car on the road.
The resolution to that particular problem was new tires. Apparently, there was a belt or cord within one tire that had broken, and was causing the steering drift force.
One diagnostic option is to switch the front tires to the back of the car.
Even though there was tread remaining on my tires, I bought an entire new set.
.... No more steering drift concerns.
Your problem description has an additional complication .... It sounds like there might be something that is mechanically wrong.
Hope you have time to update the post when you find out what's going on ......
I switched tires front to back, problem in drift solved, thanks.
The car is steering great.
I must have a defective tire also.
Also the noise in the front is still there but does not sound as bad or as
frequent.
I did inspect the front end on both sides today and everything looked and felt fine. I had two others look at it also and they said it was good, and they are almost professional.
Looks like I've got more work to do.
