wet carpet - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2011, 03:49 PM   #1 (permalink)
View ghost111's Photo Gallery
wet carpet
1999 Camry
My carpet is wet on the passengers side front. This just showed up with heavy AC usage. [ie summer in Florida] This is not anti freeze and the coolant level is right where it should be so I suspect that the AC drain tube is plugged up with ****, mold or some form of nasty stuff.
Where do I find the exit end of this tube so I can run a wire up it or disconnect it and blow it out.
ghost111 is offline   Reply With Quote
Old 07-22-2011, 04:01 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
First peel back the carpet, passenger side left -- the drain tube comes down there from the evaporator though the floorboard. Sometimes comes loose or gets pulled up through the floorboard. If all looks OK up above, you can get underneath down by the passenger side of the tranny and do a low-ish pressure flush of the tube from down below (or use one of the commercial evaporator cleaners...comes in a spray can, and available at most auto parts stores).
The Following 2 Users Say Thank You to hill8570 For This Useful Post:
ghost111 (07-23-2011), Jawadali (08-13-2011)
Old 07-22-2011, 05:20 PM   #3 (permalink)
Yoter Noob
BrightExplorer's Avatar
View BrightExplorer's Photo Gallery
See this thread:
A/C Water in Rear Passenger Floor
'00 5S-FE
Stock, unfortunately as of now...
BrightExplorer is offline   Reply With Quote
The Following User Says Thank You to BrightExplorer For This Useful Post:
