Air Conditioning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2011, 05:42 PM   #1 (permalink)
View DaveMM's Photo Gallery
USA Air Conditioning
2000 Camry - CE 5S-FE
This may be a stupid question, but where is the port where I recharge the air conditioning.
There is a port on a thin aluminum tube right in front of the radiator between the radiator and the grill, but... I went and bought a recharge kit for R134 systems and it didn't fit. Is that the wrong port or does the camry need some special adapter? It's a 2000 so I think it has to be R134.
Help!
Please
DaveMM is offline   Reply With Quote
Old 07-23-2011, 05:47 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Use the low pressure port. It'll be the larger tube.
The Jedi Speeder at CarDomain
Old 07-23-2011, 05:52 PM   #3 (permalink)
OK... where is it located?
Old 07-23-2011, 06:56 PM   #4 (permalink)
Gameroom cash: $167900
View capnblinski's Photo Gallery
The port is located right by the passenger side firewall. I have an '00 also and the cap you unscrew to access the port has an L for low on it. It is the fatter of the two pipes bending around there. The kit you have can only access that fitting, as they are made that way to prevent accessing the high side fitting - a definite no-no.
=__________________________________________=
capnblinski is offline   Reply With Quote
Tags
2000, air conditioning, toyota camry
