'94 Camry 6cyl Oil Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2011, 02:13 PM   #1 (permalink)
View i_am_jim's Photo Gallery
My '94 Camry 6cyl has developed an oil leak. Does anyone know what's the most likely culprit? I don't think it's a valve cover, but I can't figure out where it's coming from. If you suspect what may be leaking, is there a chance that tightening any of the bolts visible in these pictures would stop the leak?
Two Camrys. '94 6cyl & '04 4cyl
i_am_jim is offline   Reply With Quote
Old 07-25-2011, 02:15 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Probably leaking from the valve cover gasket, and dripping down.
BMR is offline   Reply With Quote
Old 07-25-2011, 02:32 PM   #3 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
^+1
It could also be the cam seal behind the timing cover.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 07-25-2011, 04:07 PM   #4 (permalink)
Originally Posted by pmesfun View Post
^+1
That seems more likely to me. I was able to see the valve cover gasket in this area and it'd didn't appear to me coming from there and wet area is directly behind the timing cover.
Anything I can tighten that might stop this?
Old 07-25-2011, 04:26 PM   #5 (permalink)
Avy
You have to remove the timing cover, belt, cam sprocket and metal back plate to replace the seal. Also its recommended to replace the valve cover gasket and reseal the cam seal cap under the valve cover.
99 Avalon XLS-149k
99 Lexus LS400-88k
The Following User Says Thank You to pmesfun For This Useful Post:
i_am_jim (07-25-2011)
Old 07-25-2011, 04:34 PM   #6 (permalink)
Ouch. That sounds like a lot of work. I may just let it leak. Oil is cheap.
Old 07-25-2011, 04:44 PM   #7 (permalink)
Gameroom cash: $106355
View Fortified Souls's Photo Gallery
^ If it soaks the timing belt it'll be more work best to tackle it now while its easy.
Fortified Souls is offline   Reply With Quote
Old 07-25-2011, 05:01 PM   #8 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Cam seal leak usually sends the oil down and to the rear (staying under the timing cover until it leaks out the bottom of the timing cover). This looks to be high and coming down the front and side. My money's on the front valve cover gasket.
Hit it with a can of engine degreaser, rinse, then take a look after a day or so -- should be easier to see the source.
Old 07-26-2011, 03:08 AM   #9 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
i agree that it could be a faulty valve cover gasket. easy to change the pair, just time consuming. a faulty cam seal(s) can cause an oil leak up front but not in the area in the pictures. i would replace the valve cover gaskets. remember when doing so to replace the upper intake manifold gasket and to properly apply sealer to the corners of the gasket. the worst part of the job is the removal of the hardened spark plug tube seals. they always put up a fight upon removal. i'm going to do a write up on the 3VZ-FE valve cover gasket replacement and i can post pics here of certain points of the write up if you'd like.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
