leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2011, 01:16 PM   #1 (permalink)
Gameroom cash: $326045
View adalex's Photo Gallery
4th Generation leak
Hey, long story short I replaced my exhaust manifold, only problem is on the right side (passenger side) between the manifold and the flex pipe, its leaking. I've replaced the gasket and torqued it to specs and I'll prolly try again and torque it down first on the side thats leaking but I was wondering if anybody else has any suggestions. its a 99 camry le i4
adalex is offline   Reply With Quote
Old 07-26-2011, 09:55 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
why did you replace the exhaust manifold in first place? what part used? could the new part be bent to one side?
Old 07-26-2011, 10:05 PM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
my first thought would be to a warped flange on the flex pipe. the new manifold will not seal properly, even with a new gasket, against a warped flange.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 07-27-2011, 01:48 AM   #4 (permalink)
no ive never put enough pressure to warp it, i talked to lecter and thought maybe there was some residue on the flange from the old gasket so the new gasket wasn't sealing properly, worse can i can loosen everything again and retorque everything but this time torque the problem side first
