Question about coolant level on 3VZ - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2011, 01:30 PM   #1 (permalink)
Gameroom cash: $119055
View thaharlequin's Photo Gallery
Will draining the coolant from the radiator drop the level in the block enough for me to knock out a freeze plug and install a block heater, or do I need pull the plug in the back of the block?
thaharlequin is offline   Reply With Quote
Old 07-27-2011, 01:52 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
i'd pull the block drain plug. when the engine is cool and not not running, the thermostat will be closed. so when you drain the coolant from the radiator, none of the coolant from the engine will be released into the radiator to be drained due to being blocked by the thermostat.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
The Following User Says Thank You to mazdaverx7 For This Useful Post:
thaharlequin (07-28-2011)
