Sudden Deceleration - Throttle closes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2011, 02:50 PM   #1 (permalink)
View Noblunts's Photo Gallery
Red face Sudden Deceleration - Throttle closes?
I've been driving the gen3 camry for a few days now and when I let off the gas, RPM drops very quickly. Its as if someone shut the throttle body instead of gradually closing it. With the cruise on it feels like hard engine braking just dropping 1 or 2 MPH.
Manually working the pedal at 45-55 feels pretty similar. RPM goes from 2k to like 1200 as soon as gas is released and speed drooops.
Am I correct to assume its the little diaphram near the main spring? Is that the throttle return or hold open? Acceleration and shifting seem fine.
Noblunts is offline   Reply With Quote
Old 07-29-2011, 01:47 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Seems likely to be the throttle damper (the part you mention). Fairly easy to test with a mityvac. Even without, you can get a pretty good go/no-go -- with the vac hose disconnected, your idle should bump up to around 2000 rpm (damper fully extended); with the vac hose connected at warm idle, you should be around 650 (damper pretty much fully retracted).
Tags
return, throttle body
