Manual 5 speed difference if any - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2011, 12:51 PM   #1 (permalink)
View xCaldazar's Photo Gallery
This will probably be a quick thread. I just was wondering if for the 3rd gen that 5 speed on the 4 banger and the V6 are the same transmission. From what I have read it seems they are, but I thought maybe the V6 might have something better for performance or such.
xCaldazar is offline   Reply With Quote
Old 07-29-2011, 12:59 PM   #2 (permalink)
camrtm3's Avatar
Gameroom cash: $102305
View camrtm3's Photo Gallery
They are completely different. Yes both bolt up. But they are 2 different transmissions. Even the 2 available for the 3vz and the 1mz are different.
4 Cyl Transmission
S54
V6 Transmissions
E53
E153
2009 EX-L V6 6Spd MT w/Nav (stock for now)
1996 XLE V6 Camry, KSport GT Pro 9/7, TRD RSB, E153 5spd conversion, Gen 3 front end conversion, OBX Headers, Megan Cat Back, TRD M62 Supercharger
Supercharger whine > ex girlfriends whine
http://www.cardomain.com/ride/3329124
camrtm3 is offline   Reply With Quote
The Following 2 Users Say Thank You to camrtm3 For This Useful Post:
eyeball96 (07-29-2011), xCaldazar (07-29-2011)
Old 07-29-2011, 03:12 PM   #3 (permalink)
View curry.style's Photo Gallery
What are the differences between them? Would there be a reason to choose one over another for performance?
331,000 miles and the wife's 1995 Camry LE finally bit the dust...but we can rebuild it, we have the technology...
1993 Camry LE wagon, 4 cyl, 5 spd swapped...more to come...
curry.style is offline   Reply With Quote
Old 07-29-2011, 03:30 PM   #4 (permalink)
http://en.wikipedia.org/wiki/Toyota_S_transmission
A 5-Speed Manual Transmission. The shift cable levers on the Toyota MR2's S54 are located on the front of the transmission, whereas they're located on the rear of other S-series transmissions.
Toyota MR2 Ratios:
First Gear: 3.285:1
Second Gear: 1.960:1
Third Gear: 1.322:1
Fourth Gear: 1.028:1
Fifth Gear: 0.820:1
Reverse Gear: 3.153:1
Final Drive: 4.176:1 (EU Versions have a 3.944:1 Final Drive)
http://en.wikipedia.org/wiki/Toyota_E_transmission#E153
E153
Gear ratios for this transmission.
1st 2nd 3rd 4th 5th Reverse Final
3.23 1.91 1.25 .918 .731 3.545 4.285
http://www.mr2.com/files/mr2/techinf...20e53manua.pdf
Transaxle Type E53
1st 3.538
2nd 2.045
3rd 1.333
4th 1.028
5th 0.820
Reverse 3.583
Differential Gear Ratio 3.625
Thats the info I found. Curry's conversion thread to a 5speed is what made me question this. Since the ECU wouldn't plug in I was thinking maybe it depends on the engine?
Old 07-29-2011, 04:19 PM   #5 (permalink)
Four cylinder donor car for all parts on my conversion. The only.differences between the two cars were: wagon vs sedan; auto vs manual; power Windows, etc vs manual doors. The underdash wiring is totally different on a manual car though. I'll have to repin the auto harness to the manual plugs to make the ECU work. Daily driven for four months so far with the "wrong" ECU and no issues though.
Old 07-30-2011, 03:27 PM   #6 (permalink)
Bdub215's Avatar
Gameroom cash: $316065
View Bdub215's Photo Gallery
4 Cyl Transmission
S54
V6 Transmissions
E53
E153
S54 is the 6th gen celica and 4cylinder second gen MR-2(NA) The S51 was the camry 4 banger manual.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 07-31-2011, 06:27 PM   #7 (permalink)
camrtm3's Avatar
woops. My bad. I am a V6 guy......
Old 08-01-2011, 04:02 PM   #8 (permalink)
Copied from the same link as the S54 info:
S51 A 5-Speed Manual Transmission.
Ratios: First Gear: 3.538:1 Second Gear: 1.960:1 Third Gear: 1.250:1 Fourth Gear: 0.945:1 Fifth Gear: 0.731:1 Reverse Gear: Final Drive: 3.944:1
Applications: Toyota Camry Toyota Solara
Old 08-01-2011, 04:02 PM   #9 (permalink)
Old 08-01-2011, 04:37 PM   #10 (permalink)
View astatcamry956's Photo Gallery
So what transmission would be better the the V6 after seeing the gear ratios..
astatcamry956 is offline   Reply With Quote
Old 11-10-2011, 10:25 PM   #11 (permalink)
I cheated with 7075 Al
N/A Camry Sleeper's Avatar
Gameroom cash: $161600
View N/A Camry Sleeper's Photo Gallery
Depends on what you want - For cars making gobs of power go with the E153 - it can take it for the most part. If you have a highway cruiser, then go for the E53 with the lower numerical final drive.
The final drives will interchange between all three transmissions - so you could theoretically put the 3.625 FD from the E53 into the E153 for the best of both worlds.
I have the S54 in my 1996 Camry and at 78 MPH the car cruises at 3000 RPM. If I changed to the E153 and used the FD out of the E53 I could drive the same speed but only be turning over 2300 RPM with not much changed with the other gears as far as performance. That would mean a significant increase in gas mileage - but I don't know of anyone who's done this (yet)
1996 Toyota Camry 5SFE 5-spd 329.9K - UNDER REPAIR
1997 Honda Civic 1.6 5-spd - 183K and 27 MPG average - Dependable DD and *small* family car
1991 Acura Integra 1.8 5-spd - 241K and 28MPG average - I'm game for a simple LS Vtec swap now...
N/A Camry Sleeper is offline   Reply With Quote
Old 11-11-2011, 03:05 AM   #12 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Oh man, I wish someone did it cause cruising at 70 mph at 3500rpm kills my gas like nothing. =| I wish my gears were higher so that I can cruise at lower rpm.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 11-11-2011, 06:10 AM   #13 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
^ agreed. Only complaint I've had about this car. Or maybe a 6th gear would be beneficial.
Chris Crash is offline   Reply With Quote
Old 11-11-2011, 12:05 PM   #14 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
Damn, with my Civic I am only at little bit above 3000rpm at that same speed.
TTercel is offline   Reply With Quote
Old 11-11-2011, 12:08 PM   #15 (permalink)
View SirThomas88's Photo Gallery
Okay, now the next question is... how does the E351 trans fits in with these other trans?
The E351 is the Scion tB manual transmission. I have a Quaife LSD sold for the E351 but I think it may be a direct fit into the E153 (Camry v6 5 speed) just fine. Anyone have a clue?
SirThomas88 is offline   Reply With Quote
