Originally Posted by dorifuto.boi
does this really work ?
Believe it or not, YES!
My brother and I tested it on his S13 after he got his SR20DET swapped into it.
The difference is very noticeable. While 30F isn't a big number in terms of how hot your parts get, that's still quite a good bit to cut out. Its also good because your intake will draw in cooler air as from before.
I must also add, the cheap stuff rips and breaks easy, the more expensive stuff lasts much longer.
OP, I would probably try run a A2W intercooler set up.
What you could do is mount your water tank around where the battery is located and reroute your intake, then put the intercooler on the coolant reservoir side.
Depending on how thick your intercooler is, you might be stuck having to run a single core radiator for it.
But as far as cooling goes, I would probably use water with water wetter. If you plan on really running is for lengthy periods, or not, you could substitute some dry ice in there.
Just remember, if you don't cut out temperatures in your engine bay, you can still potentially heat soak if you don't have the I/C or tank properly placed. Make sure the I/C gets at least
some air flow.
Also, because money is a huge issue on this board, expect to pay about $1000 on a decent A2W kit. I spent $1100-1150 on the one I put together for my MR2.
