95 Camry Front Speaker Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2011, 02:28 AM   #1 (permalink)
View lilpenny1's Photo Gallery
I want to install after market 6 1/2 front speakers. Where can I get the speaker wire connector adapter or what kind do I need to connect the speaker plug to the new speakers. THanks in advance.
lilpenny1 is offline   Reply With Quote
Old 07-31-2011, 03:49 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
you can get the adapters form best buy. you may want to check though as i believe you may need speaker adapters to fit the new speakers on the doors.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 07-31-2011, 07:16 AM   #3 (permalink)
View JustinC25's Photo Gallery
Speaker adapters are not required. You can buy the harness at bestbuy, or from crutchfield, but why not just cut the factory speaker wire, and use crimp connects on the factory wire from radio shack.
Here is a pic with the factory bracket
This tab will hit on the after market speaker
Just take out these 2 screws from the back of the door panel
You can cut if off with a pair of wire cutters like this
Then you will be ok.
2010 Camry 2AR-FE 6 Speed in Blue Ribbon 22k
1995 Carmy 5S-FE Auto in Super White 272k
JustinC25 is offline   Reply With Quote
Old 07-31-2011, 09:49 PM   #4 (permalink)
Ok, thanks guys. @Justin. I'm a little confused with the pictures. Is that a 6 1/2 kenwood in the stock harness or a different harness. Also I haven't taken the stock speaker out yet so did you re-wire the kenwood inside the harness to work with the white plug connector.
Old 07-31-2011, 10:59 PM   #5 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
All you need:
Done.
Chris Crash is offline   Reply With Quote
The Following User Says Thank You to Chris Crash For This Useful Post:
projektvertx (08-04-2011)
Old 08-04-2011, 07:05 PM   #6 (permalink)
This is a 6 3/4" Kenwood 3-way, I used the stock harness, and bracket. I unscrewed the 4 screws and pulled out the factory speaker.
Then I looked at the back of the speaker to see which wire was positive and which was negative.
Then I cut the factory wires off the factory speaker, as they are soldered on.
Next I stripped the wires, and bought some crimp connectors in the correct size blades (Wide for positive, and narrow for negative) from Radio Shack, Then I crimped the ends on and installed the new speaker. Finally I removed the grille from the door panel, and cut the tab off, then reinstalled it on the door panel, and put everything back together.
The rears were a little more work, because I used Kenwood 6"x9"'s
and the factory holes don't line up.
I had to drill holes, and use bolts for the rear.
I could have used a 6 1/2", but I wanted the better bass response of the 6x9's
(They make a nice adapter bracket for the rear deck to use 6 1/2's with no drilling.)
