Originally Posted by lc1500mc
I slid under and forund that when I pushed upwards a bit, a heavy knock (like a small hammer on the frame) would occur at he junction of the stabilizer bar and the stablizer bar link (the small bar that attaches to the strut.) When disconnecting the juction, the knock disappeared.
The issue seems to be the lower joint of the stabilizer link. You can feel the knock while holding the stabilizer or the link.
Can a bad lower stabilizer link cause such an noise?
Definitely. And everything you've said points to it as the source of the noise. There might be more that's wrong, but your link is definitely bad. There should be ZERO detectable play in them.
