My 92 Camry wont start someone help please?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2011, 05:42 PM   #1 (permalink)
View rigocb7's Photo Gallery
ok so yesterday the car started miss firing looked under the hood and the spark plug wire for cyl 3 had a crack in it and was throwing a spark through there. i wrapped it in electrical tape mean while i drove to autozone to buy a set of new wires a cap and a new rotor. but before we put anything on me and a friend had the bright idea of pressure washing the engine bay, once we were done i turned on for about 30 seconds threw a check engine light and turned off. after that we noticed that water got in were the spark plugs are at. it wasnt much so we vaccumed all the water out and i checked all of the fuses under the hood and they were all good. after that we put on all the parts i bought and nothing it just turns over and smells like gas after a while. i also hooked up the scanner to it to check what the check engine light came on for and we got no thing no codes evercame up. iive ran out of ideas of what else might be wrong with it can anyone help please the car is auto 4cyl
rigocb7 is offline   Reply With Quote
Old 07-31-2011, 09:45 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Yer gonna need to git some WD-40 and spray yer plug tops and wire boots. Just so you know...WD-40 was formulated as a water displacement...hence the WD designation.
WD-40 FAQ...
What does WD-40 stand for?
WD-40 literally stands for Water Displacement, 40th attempt. That's the name straight out of the lab book used by the chemist who developed WD-40 back in 1953. The chemist, Norm Larsen, was attempting to concoct a formula to prevent corrosion-a task which is done by displacing water. Norm's persistence paid off when he perfected the formula on his 40th try. Please see Our History for more information.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
