right rear drum brake noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2011, 10:00 AM   #1 (permalink)
View redhead54's Photo Gallery
I have a 1996 camry le 4 cylinder...disc brake front...drum brake rear....135,000 miles. I did 4 wheel brake job including drums and rotors. Used wearever shoes on the rear. Immediately after the job I had a clicking noise in the right rear on stop. I rechecked everything...installation OK. I searched everywhere on the NET including here for a fix. I spent hours researching. I found the answer and I want to share it. It is a known problem after 100,000 miles that the rear wheel cylinders should be replaced whether they are leaking or not. Toyota will not share this. Also....make sure the replacement shoes....if you are not using genuine toyota parts.....have two different sizes....one is longer and one is shorter....wearever were not like this.....I used Beck and Arnley shoes from Rock Auto.
redhead54 is offline   Reply With Quote
Old 08-01-2011, 10:35 AM   #2 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
Welcome......and thanks for the info!.........gotta love rockauto.com and don't forget you can get a 5% discount........when you have a chance creat a detailed signature/profile of your car....the forum works better with a nice sig!!!!
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 08-02-2011, 12:53 AM   #3 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445745
View uibalnme's Photo Gallery
Rear disc swap FTW!!! Sorry, I just had to say it.
Welcome to the forums, and a for finding a solution to your troubles.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 08-02-2011, 05:03 AM   #4 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
please advise how the wheel cylinder was making a clicking noise.. i can see if maybe the piston were worn into the bore on the wheel cylinder..but at that point you'd most likely see some leakage. i always replace the shoes and wheel cylinders together as a pair on drum brake equipped cars. saves on issues down the road and ensures many more miles of good braking.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
