transmission wont shift - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2011, 10:01 PM   #1 (permalink)
View newskooler's Photo Gallery
hey guys so ive continued to have bad luck with my gf's 1999 toyota camry with the I4 and AT. in my previous post i had a problem with the car starting and found that the crank sensor wiring was exposed and grounded out, i of course found this after buying new ignition coils,plugs and wires. luckily the coils are still in thier boxes. so after fixing that issue the car started and now runs like a champ.
here comes the new issue... the car wont shift without being rev'd up to around 4-5k rpms.n. it shifts smoothly into reverse and drive and exellerates all the way up to that point.
any ideas or links?
1999 toyota camry le I4 AT aka carl all stock
2003 toyota tacoma Trd sr5 3.4L V6 k&n intake 5spd, OME 881s 5100s trailgear front bumper and sliders custom rear bumper and more to come
newskooler is offline   Reply With Quote
Old 08-01-2011, 10:18 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Is this a new problem, or did it exist before the starting issue?
You sure it's having to rev that high? That's damn near redline -- it's going to be kicking you hard in the ass every time it shifts with that high of a shift point.
Old 08-01-2011, 10:20 PM   #3 (permalink)
Dave's
Gameroom cash: $121550
View Dave's's Photo Gallery
Sounds like a shift solenoid is stuck. But this should give you a check engine light (if it's working- which you can check when starting the car..) If the book is right you can disconnect the electrical connectors to the solenoids near the park/neutral switch (2). Then manually shift thru the gears from 1, 2 and D. If it shifts properly then there's probably a solenoid or electrical problem. WARNING: if you do this test you will get a check engine light and will need a way to reset it.
Last edited by Dave's; 08-02-2011 at 03:11 AM. Reason: Got home and read the book.
Dave's is offline   Reply With Quote
Old 08-02-2011, 09:30 AM   #4 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
any ideas or links?
not to be a smart ass.........but we told you it was not the coil-packs and you ordered them anyways..........did you check the fluid level......you need to check the fluid level with the car running...........get a scanner and see if you are getting any pending codes?
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 08-02-2011, 10:06 PM   #5 (permalink)
camrtm3's Avatar
Gameroom cash: $102305
View camrtm3's Photo Gallery
What is with that hate? Seriously. What does an old problem with starting and coil packs have to do with transmission issues?
Possible issues:
Shift solenoid. After a while this will throw a code. Pain in the ass to replace.
Speed Sensor failing. Well the ECU looks for throttle position and speed to shift. If its failing, well. Symptom, Speedometer would be acting up. This too will throw a code.
Eventually the ECU will get pissed at you and throw a code at you. The gen 3 and gen 4 camry is very simple ECU and there are no "hidden" code like in the new cars. If it does not like something it will tell you.
2009 EX-L V6 6Spd MT w/Nav (stock for now)
1996 XLE V6 Camry, KSport GT Pro 9/7, TRD RSB, E153 5spd conversion, Gen 3 front end conversion, OBX Headers, Megan Cat Back, TRD M62 Supercharger
Supercharger whine > ex girlfriends whine
http://www.cardomain.com/ride/3329124
camrtm3 is offline   Reply With Quote
Old 08-03-2011, 01:25 PM   #6 (permalink)
Haha I know sounds dumb but I like to make sure all the bases are covered the reason I even ordered the coils os because there was corrosion in it so I figured id pick up a set while I was online just in case. I'm getting my money back so not a big deal.
I checked the solenoid and connections like you guys said and the car still won't shift. And there wasnt any codes thrown prior to disconnection of the solenoid.
and yes the fluid levels where good
I finally broke down and took it t a shop and they said the manual valve was toast. Then I hear from the gf she put it on park while it was still rolling so i'm guessing she chipped something off and it ended up damaging the valve?
anyways thanks guys and i'll post up some pictures for you tomorrow when I get it back
Old 08-03-2011, 08:35 PM   #7 (permalink)
camrtm3's Avatar
Your head is going to hurt man. The park pin in the trans is quite large. That thing doesn't break with out some force. Trust me I tried to break my old AUTO so my dad would help pay for my 5spd swap. That is one of the techniques I used. Rolling is an understatement. I tryed at the end 5 times with 5 mph "rolls" and the damn thing didnt break. She had to be doing an excess of 5mph.
Old 08-03-2011, 09:38 PM   #8 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
so the shop said that valve body is bad? if so you should be able to remove it and inspect it for cracks or sticking valves..
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-03-2011, 09:42 PM   #9 (permalink)
camrtm3's Avatar
That is a bitch to do. Have to drain the trans. And there are about 30 10mm bolts that hold that. I took one apart to rob solenoids. ya, not fun. let them do it or get a new car. Sorry that is skinny on that.
Old 08-03-2011, 09:53 PM   #10 (permalink)
mazdaverx7's Avatar
if the shop does the work then great! if not, then the guy may want to drain the trans and clean and inspect the valve body. heck, it may work and he'd get a new trans filter and fluid to boot! if not he's out some time and a few bucks.
85 RX-7 GS 5spd
Old 08-04-2011, 12:55 AM   #11 (permalink)
haha ya screw it the shop will have it done by lunch tomorrow. the shame is it has new fluid and filter oh and the 500 dollar price tag F***. thank you guys though.
Old 08-04-2011, 03:08 PM   #12 (permalink)
Woodyg's Avatar
sorry about the fluid question ........I did not know you were ASE certified......you should add that to your sig........................when you dropped the pan to check the solenoids did you see anything unusual?.......................not sure what the VB cost but on most tranny once the pan is dropped the swap is about 20 minutes................but what the heck it's only the GF money and the tranny guys have to eat too.....
