Instrument cluster screws won't back out
Using Dark-LE's "DIY--Needle Color Change" DIY (aka "Cluster Needle Color Change" from the DIY sticky), I wanted to replace the light bulbs that light up the gauges in the instrument cluster of my 2001 LE - the bulb for the temp gauge is out & I thought I might as well replace them all at once.
Well, I can't even get past step one because the Philips screws above the gauges will *not* unscrew - can't even get 'em started, either one. Tried a couple different sized short Philips screwdrivers but can't get the bleedin' screws to budge even a smidge; also, the screwheads seem to be slightly stripped, as if someone else tried the same thing before I bought the car.
What makes it harder, too, is you're pressing up from underneath w. limited space, and since you're basically pushing up into where the top of the bezel meets the padded dash overhang you don't want to push TOO hard... even if you're also pushing down on top of the dash overhang with the other hand at the same time, if you get my meaning.
Any suggestions would be most welcome!
Thanks!
