See if you can find the speed sensor on the transmission.
The FSM diagram shows it to be a little to the left and a little straight back from the oil filler cap ... if you are standing in front of the engine.... I think that is the oil filler cap.
It should have three wires:
red with blue stripe .... going to 10A Gauge Fuse ... this is terminal #1
purple ... this is terminal #2
light green ... this is terminal #3
Also just check the 10A Gauge Fuse .... since it is easy to get to ( fuse box behind the coin tray inside the passenger cabin).
The manual gives a basic speed sensor test ... just connecting 12v, rotating the axle and observing voltmeter output change.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
