4cyl. Timing Belt Change, Necessary to do it at Schedule Mileage? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2011, 07:16 PM   #1 (permalink)
View Brit101's Photo Gallery
4th Generation 4cyl. Timing Belt Change, Necessary to do it at Schedule Mileage?
2000 Camry 4cyl. Have you found the timing belt to be in very good condition when you changed it, and felt you could have postponed the maintenance?
Mine is at 106k mi and there is no way that I can see to check it without removing lots of bits.
Non interference, so what do you say, change it, run it until 130k mi or check it some way?
Drive the car little and wondering what your advice is.
Have CAA/AAA Gold and timing belt and waterpump in the trunk.
TAI.
Brit101 is offline   Reply With Quote
Old 08-03-2011, 10:25 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
Changing the T-belt out is more to avoid the inconvenience of being stuck on the side of the road. There won't be any engine damage but it's troublesome to fix it unexpectedly. I would make time to change it out with the water pump as well as the tensioner and idler pulley. Having said that, I had a Quest that went 185K on the original timing belt and the letters were still visible.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
The Following User Says Thank You to Yuko For This Useful Post:
Brit101 (08-04-2011)
Old 08-03-2011, 10:31 PM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
timing belts are maitenance items that should be changed every 60K miles. mine was changed at 62K and i'm at 131k and the belt looks to be ok. looks can be decieving though. you should remove the timing cover and check it for stretching and any stress cracks or glazing.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
The Following User Says Thank You to mazdaverx7 For This Useful Post:
Old 08-03-2011, 10:32 PM   #4 (permalink)
mazdaverx7's Avatar
somehow got a double post. stupid work computers..
85 RX-7 GS 5spd
Old 08-03-2011, 11:42 PM   #5 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
The interval on the 2000 Cams is 90K. It's amazing how long some folks go before their timing belt breaks. Personally, I wouldn't let it slide too long, but I don't like being towed, either.
The Following User Says Thank You to hill8570 For This Useful Post:
Old 08-04-2011, 12:40 AM   #6 (permalink)
View bolink654's Photo Gallery
My wife got our 98 Camry before I met her, it had about 110k on it. The previous owner kept records of everything, and a timing belt nor water pump was not in the records... And neither her nor her parents ever had it done, so I am to assume it was original.
The water pump went out at 165k or so. Changed the timing belt at the same time. IF it was in fact the original, it looked really good, looked worse for age, than it did for wear. (which is kinda why I believe it was original - it looked 10-11 years old)
82 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
1998 Toyota Camry - 5S-FE, Auto - 205k
82 Toyota pickup - 20r, 5spd, 4wd - SOLD
bolink654 is offline   Reply With Quote
The Following User Says Thank You to bolink654 For This Useful Post:
