Experiencing shaking/vibrating steering wheel when braking at high speeds? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2011, 10:22 PM   #1 (permalink)
View guccimane's Photo Gallery
4th Generation Experiencing shaking/vibrating steering wheel when braking at high speeds?
so I've noticed when I brake suddenly or at high speeds the steering wheel will shimmy/shake/vibrate.
is this not caused by poor alignment? that was my first guess, but Google results seem to suggest warped rotors.
what are you guys' thoughts?
p.s.: 2000 Camry LE, 15" wheels, if it means anything lol
guccimane is offline   Reply With Quote
Old 08-04-2011, 10:49 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
As you suggested, warped rotors is the prime suspect. How is low speed and light braking?
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 08-05-2011, 03:42 AM   #3 (permalink)
View SirThomas88's Photo Gallery
if its your alignment or tires, you wouldn't only feel it while braking. you need to replace your rotors.
SirThomas88 is offline   Reply With Quote
Old 08-05-2011, 05:48 AM   #4 (permalink)
View reidcc's Photo Gallery
B4 U replace your rotors though-
You should have your calipers and slide Pins checked to make sure they are not siezed. If they aren't moving, you will be replacing rotors again very soon.
Chris
reidcc is offline   Reply With Quote
