trd rsb advice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2011, 05:15 PM   #1 (permalink)
Gameroom cash: $326045
View adalex's Photo Gallery
4th Generation trd rsb advice
In the process of getting a trd rsb for gen4 camry I4, my car has been in florida his whole life so I don't think the bushings, endlinks etc are rusty. Just wondering what you guys recommend for grease etc for the bushings? Adam recommended teflon tape around the bar where the bushings will go and then around the bushings themselves. what you guys think?
thanks
edit: heres two pics of the bar im getting
adalex is offline   Reply With Quote
Old 08-06-2011, 03:05 AM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Yeah, do what he said. I used white lithium grease.
RichieRichJP is offline   Reply With Quote
Old 08-06-2011, 04:44 AM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
they actually make grease specifically for use on bushings, especially poly bushings. this prevents any squeaking.
http://www.ss396.com/mm5/merchant.mv..._Code=elcamino
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-06-2011, 07:09 AM   #4 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
Yeah, use teflon tape or lithium grease. I didn't at first and the squeaking drove me crazy.
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 08-06-2011, 12:23 PM   #5 (permalink)
hows this? http://www.autozone.com/autozone/acc...fier=10463_0_0_
Old 08-06-2011, 12:47 PM   #6 (permalink)
TN's Mad Chemist
^That's good Harbor Freight sells the teflon tape roll for 99 cents, if you have a harbor freight near you
1997 Acura RL-Gone
Old 08-06-2011, 01:06 PM   #7 (permalink)
yea theres one a little down in the county, like 15-20 mins. the only teflon tape that pops up is thread seal tape?
Old 08-09-2011, 11:32 PM   #8 (permalink)
ok frusturated as all get out. ok long story short i had to put the stock one back in because I couldn't get the brackets in. I took off the passenger side rear wheel but not the left but i got the rsb off and on no problem. My question is do I need to replace the brackets with like energy suspension ones? or will they still work with the stock brackets and I just need to take off the other wheel?
Old 08-10-2011, 01:44 AM   #9 (permalink)
I hope you had both side jacked up when you did this
By this : "I took off the passenger side rear wheel but not the left but i got the rsb off and on no problem," it looks like you jacked up one side at a time and tried it.
Old 08-10-2011, 02:33 AM   #10 (permalink)
yes both sides were jacked up and off the ground and on jackstands
Old 08-10-2011, 02:07 PM   #11 (permalink)
anybody have any idea? should i buy energy suspension brackets? and use the trd bushings? and somebody on solaraguy said something about if the back end is out of alignment it can cause issues?
Old 08-10-2011, 02:36 PM   #12 (permalink)
TN's Mad Chemist
I got mine from bigbird with the brackets, and it was my understanding that the stock Gen4 brackets are what is compatible with this bar
1997 Acura RL-Gone
Old 08-12-2011, 02:28 AM   #13 (permalink)
just found out something, assuming I did it right. I used the rear sway bar little measuring tool that i printed out on the 57th page of the energy performance products pdf listing and according to that the trd bar is 20mm
sorry about the fuzzy pics its not lined up perfectly but its really close
Old 08-18-2011, 09:30 AM   #14 (permalink)
RA29 Dreams's Avatar
View RA29 Dreams's Photo Gallery
Any luck getting this installed? If not, I'll buy it off you!
Sorry i've just been looking for a TRD RSB for my camry for a LONG time with no luck. Where'd you land yours if you don't mind me asking?
RA29 Dreams is offline   Reply With Quote
Old 08-19-2011, 03:20 AM   #15 (permalink)
yea i got it in, had a friend help hold it up while i algined the bracket it really was a pita and i think it was so difficult was because the bushings had already been compressed before so i had to recompress them to get them in but my friend said in like 6 months or after a little bit if i take it off again it should just screw right in.
i got it from one to hate he was selling it for another member.
Mileage on stock rsb/new rsb ( a baby i know) XD
OH ALMOST FORGOT: For anybody who reads this who had issues with rust etc, I prolly had the easiest install ever,minus actually putting the brackets in since i can't hold both sides of the bar up and screw it in at the same time. the endlinks loosened with a ratcheting box wrench without allen key and not a drop of pb blaster was used :P
if anybody else need to take off the rsb for any reason i figured out the best way to do it.
1. undo the rsb itself u can take the brackets off
2. undo the 2 nuts holdiing the second from the last hanger of the muffler, the muffler was held up just fine when i took those two off
3. undo the 3 8mm nuts holding the middle heat shield off ( the one between the cat and the muffler) and slide it off to one side like rotate it around the exhaust pipe
4. i took my bar out from the driver side so i took off the bracket and the bushing off the passenger side and was easily able to rotate the bar and push a little on the pipe and the bar comes straight out if i can ill take pics of the exact stuff
