1997 Camry 2.2L - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2011, 10:07 PM   #1 (permalink)
View downtown90's Photo Gallery
1997 Camry 2.2L
I had to replace the water pump and the timing belt and the Crankshaft Possitioning Sensor and my 1997 Camry 2.2L still runs ruff, no exceleration and smells very rich. It sounds like the exaust is being restricted too. I checked the flow at the tail pipe and seems to be normal. Dows anyone have any ideals as to what can be still wrong?
downtown90 is offline   Reply With Quote
Old 08-07-2011, 11:28 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
did you check the timing with a timing light after the belt install? did you replace the timing belt tensioner when you did the timing job?
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
The Following User Says Thank You to mazdaverx7 For This Useful Post:
downtown90 (08-08-2011)
Old 08-08-2011, 05:16 AM   #3 (permalink)
Gameroom cash: $177500
View ShawnTRD's Photo Gallery
Need more info then that. Was these problems you were having before doing the timing belt, water pump, and cps? What other maintenance has been done and when?
MY 1998 Toyota Camry LE
http://www.toyotanation.com/forum/sh...d.php?t=368035
ShawnTRD is offline   Reply With Quote
The Following User Says Thank You to ShawnTRD For This Useful Post:
Old 08-08-2011, 06:31 AM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Sounds like the timing is off a cpl teeth, or your upstream o2 is Out of spec and mixing ur fuel mixture all crazy or a combination of the two
The Following 2 Users Say Thank You to Mister_Perkins For This Useful Post:
downtown90 (08-08-2011), ShawnTRD (08-08-2011)
Old 08-08-2011, 12:18 PM   #5 (permalink)
What happened was I was my Water pump failed and when it falied so did the timming belt and the car just died!!! So I replaced the timmingbelt and the water pump. I inspected the Crankshaft possitioning sensor and seen that it was damaged I replaced it too. Now when I scan the car.... I get P340 circuit malfuction. I traced the plug wires back to the main wireing harness and could not find any cuts\damage. What next?
Old 08-08-2011, 01:27 PM   #6 (permalink)
Maybe you got a bad CPS. Did you get it from Toyota?
http://www.obd-codes.com/p0340
downtown90 (08-09-2011)
Old 08-10-2011, 12:02 AM   #7 (permalink)
You were right about being a couple of teeth off. Its ALIVE!!!!! Thank YOU!!!
