Replacing Valve Cover Gasket - Need to drain oil? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2011, 01:29 AM   #1 (permalink)
Noob
View scrapdawg02's Photo Gallery
I am going to attempt smilecow's DIY on replacing the valve cover gasket (DIY valve cover gasket (pics)) and was wondering if I needed to drain the oil first? Sorry if that is a dumb question...
Also, is there anything else that should be done while the valve cover is off? I've read that people usually also replace the spark plug seals... where are these and are they easy to change?
Thank you!!!
scrapdawg02 is offline   Reply With Quote
Old 08-09-2011, 01:52 AM   #2 (permalink)
View bolink654's Photo Gallery
The seals he has pictured go under the 29mm nuts, I believe.
I see no need to drain the oil. Often times in older vehicles, people adjusted the valves with the valve cover off and the engine running.
82 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
1998 Toyota Camry - 5S-FE, Auto - 205k
82 Toyota pickup - 20r, 5spd, 4wd - SOLD
bolink654 is offline   Reply With Quote
The Following User Says Thank You to bolink654 For This Useful Post:
scrapdawg02 (08-09-2011)
Old 08-09-2011, 03:01 AM   #3 (permalink)
pro nub
View trdcamry00's Photo Gallery
The 4 seals are under the 30mm nuts.
trdcamry00 is offline   Reply With Quote
The Following User Says Thank You to trdcamry00 For This Useful Post:
Old 08-09-2011, 06:10 AM   #4 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
no need to drain the oil on a valve cover/spark plug tube seal replacement job.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
The Following User Says Thank You to mazdaverx7 For This Useful Post:
scrapdawg02 (08-11-2011)
Old 08-09-2011, 06:35 AM   #5 (permalink)
Yoter Noob
BrightExplorer's Avatar
View BrightExplorer's Photo Gallery
Nope, no need... as it has been said...
Welcome to the forums.
Remember, there are no stupid questions if you don't know what you're doing... You've got to learn some way right?
'00 5S-FE
Stock, unfortunately as of now...
BrightExplorer is offline   Reply With Quote
The Following User Says Thank You to BrightExplorer For This Useful Post:
