Relief Valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2011, 05:04 AM   #1 (permalink)
View tweak1029's Photo Gallery
Relief Valve
A while ago I changed my oil pan gasket and while I was in there I cleaned the relief valve because on startup I have a 1-4 second delay before I get any pressure, and the pressure does not rise as much as it should per revolution. 25 psi seems to be the max while hot and 55 cold. It idles around 50 psi cold. The valves rattle while passing or accelerating when hot.
When I got the c-clip out only three parts fell out, the clip, a washer that goes between the spring and c-clip, and the spring. The valve itself did not come, and I couldn't get it out (though I didn't grab it and force it). It didn't move very easily at first but then after I cleaned it I could push it up a bit and it would fall back down some. How is the valve supposed to act? Should it travel the whole bore freely? I saw no other way of getting it out, so that must have been how it got in there.
I have college coming up soon and I'll need the car then so I have to find out where my pressure is going.
tweak1029 is offline   Reply With Quote
Old 08-09-2011, 06:22 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Yup the valve should just slide out really easily with a light coatin of oil. I would suggest pulling that relief valve out and honing that cylinder it rides in. More than likely there's a lot
Of varnish in there causing it to be stuck.
Old 08-11-2011, 05:07 PM   #3 (permalink)
Anybody got the part number for the oil pump gasket? I'm having a hard time finding just the gasket... They tend to come with a new oil pump.
Old 08-11-2011, 05:21 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Year of the car and the engine would be real useful information at this point.
And are you looking for the big gasket (that seals the main housing to the engine) or the o-ring (that seals the smaller housing containing the rotor to the main housing)?
Old 08-11-2011, 05:24 PM   #5 (permalink)
Main housing to block. It's a 92 5SFE.
Old 08-11-2011, 05:34 PM   #6 (permalink)
hill8570's Avatar
Believe that would be 15197‑63021 (Gasket, Oil Pump). List is around $6.
If you're not in a hurry, I've got a Toyota OEM one out in my parts bin I could let you have for cost of shipping. Given the list price, 'tho, that probably wouldn't save you much.
Old 08-11-2011, 06:06 PM   #7 (permalink)
That works for me. Send me a pm with your paypal info.
1992 Camry Wagon 4 Cyl
Old 08-20-2011, 05:36 PM   #8 (permalink)
I cleaned the relief valve and it works fine now, but the problems persist. I'm afraid my low oil pressure may be from worn bearings. Next time I get a chance to mess with it I'll remove the balance shafts and see how much that affects my oil pressure. If I can afford it I'll replace the main bearings while I'm there, but it will probably be a while until I can do anything because I start college tomorrow.
Thanks for the help.
Old 08-21-2011, 04:36 AM   #9 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Relief valve setting is whatever the spring rate is. It's possible I guess that the spring is weak. You could try a new spring and see if that improves pressure.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
