94 Camry Steering Rack Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2011, 11:52 AM   #1 (permalink)
View bdc961's Photo Gallery
Hi all,
I am new here so I hope this is posted in the correct place, if not please redirect me.
I have read the following write-ups for the referenced title.
http://www.toyotanation.com/forum/showthread.php?t=329597
http://www.toyotanation.com/forum/t108185.html
Excellent work by both. My question is this. When removing the rack will the joint connected to the pinion shaft articulate enough to remove the rack? Both write ups describe the removal of the rack as a, " push pull and twist in every direction" to remove it. The write ups are not very discriptive about how the pinion shaft will slide out of the steering joint. The steering joint has only one bolt to remove from a coupler that, "pinches" the pinion shaft. Am I missing something in both write ups?
Thanks for your help.
bdc961 is offline   Reply With Quote
Old 08-13-2011, 01:57 AM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
The "steering joint" known better as the "steering intermediate shaft" which connects the steering wheel to the rack is collapsible. There are splines cut into the input shaft or "pinion shaft". After removing the bolt that clamps the joint onto the rack, the intermediate shaft can slide up towards the firewall away from the rack.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
