Originally Posted by hill8570
Pretty sure the lightning bolt piece goes between the the top and bottom...probably attaches to the lower edge of the top cover. Foam...no idea...never seen a rig with the foam intact
I see now. You were close, it goes on the outer edge of the lower cover, near the top...there is a raised ridge that it goes over, facing the tire, to give the upper cover a seal to rest on/rub against.
I first saw the foam seal
midway thru this thorough DIY, but he doesn't seemed to have mentioned the rubber one, which bits and pieces of the old one were still attached on mine (except were of hard plastic.) I guess I'm going to have to assume it gets sealed to this rubber, since the rubber seems better protection than the foam.
