Originally Posted by web gem 5
97 auto v6
1. are there any bolts securing the shaft into the Trans like on some nissan?
2. am i going to be able to get the shaft off (through) the lower engine mount without difficulty? Soaking in PB now, I know I will have to remove the snap ring and lower mount bolt.
3. If fluid is lost, where do I refill? Is it different from the ATF?
4. Whats best for a stuck shaft? Whale jaw vise grip and hammer?
Thanks guys
Your mileage may vary with this, but I just recently replaced mine (98, v6 auto).
I say attempt to remove because I spent a few hours pulling, hitting and cursing at the shaft before half of it pulled out and I had it towed to a shop to have the remaining shaft piece removed. At thenshop, it took two guys, one with a pneumatic hammer and then other with a pry bar to get the shaft out of the mount.
There is a video online of a guy who removes the motor mount, then cuts the shaft off to hammer it out, before puttingnthe mount back in the car, but unless you have some experience with that, you could be looking at a huge headache especially if the engine isn't lined up when you try to put the mount back in (note: you would obviously need to suspend the engine with either an engine hoist, or jack from underneath the oil pan with this method).
I couldn't tell you about the fluid question, I've never had fluid leak when replacing a shaft.
As I said before, your mileage may vary, but for me it was quite the pain in the ass.
