2001 Camry Differental Fill Plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2011, 09:29 PM   #1 (permalink)
View tony1967's Photo Gallery
I have a 2001 Camry and I need to change my differental fluid, but I cannot get the 17 mm fill plug off. I have rounded it and I bought a craftsman bolt remover but cannot use it because I have to pound it in. There is no room to pound it in.
tony1967 is offline   Reply With Quote
Old 08-14-2011, 10:45 PM   #2 (permalink)
You might not actually need a wrench to get the fill plug off.
I don't recall the access to the fill plug, but if there is room to get a prick punch, of whatever convenient length, onto the surface of the plug, you can hit it a few times, and it will probably come loose. This has worked lots of times before for me.
A prick punch is just a steel pointed chisel ... with a hardened point.
Try two or three different spots around the outside edge of the plug.
... Make sure that you are striking it so that it will turn in the correct direction ...
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 08-14-2011, 11:03 PM   #3 (permalink)
View bolink654's Photo Gallery
Also try vice grips or channel locks. And look around, some bolt extractors do not need pounding on, as they are spiraled inside (the more you turn the more it digs in)
82 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
1998 Toyota Camry - 5S-FE, Auto - 205k
82 Toyota pickup - 20r, 5spd, 4wd - SOLD
bolink654 is offline   Reply With Quote
Old 08-14-2011, 11:05 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
+1 on the chisel method, a large chisel and hammer works great for this kind of thing, just make sure you get a good bite into the bolt before you start hammering on it.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 08-14-2011, 11:10 PM   #5 (permalink)
fill pug rounded
The vice grip and bolt extractors tried both methods and the head of the bolt started to fall apart. I still have the base of the bolt in tack but not much more. The bolt extractors cannot get that thing pounded in it keeps slipping when try to turn it. Hammer and chisel may be only hope.
Old 08-14-2011, 11:10 PM   #6 (permalink)
Try to get an actual 'prick punch'. It has a sharpened point that will grab onto the plug surface.... it doesn't matter if it's damaged or not. ... Main issue is if you have enough room to swing a hammer onto it.
Sometimes, if there is corrosion on the threads, you can try to turn the plug in the 'tighten' direction once or twice, and it will help it to break free.
After you get it loose, just get a new plug .... and some teflon tape.
The Following User Says Thank You to dc_98_cam For This Useful Post:
tony1967 (08-20-2011)
Old 08-14-2011, 11:21 PM   #7 (permalink)
Wow. Sounds like it is seriously stuck. Yeah chisel/punch and a hammer sounds like the next thing to try.
Always happens on the simple jobs too huh? I had a oil filter stick on a dodge pickup once. Ended up tearing off the metal, the filter inside and then still had the threaded plate part of the filter stuck on!! It had holes in it though, a screwdriver in the holes (same idea as punch and hammer) and hours of beating and cussing and it did finally come off though. Hopefully it works for ya.
Old 08-14-2011, 11:35 PM   #8 (permalink)
71Corolla's Avatar
I would heat it with a torch before using the chisel, that's your best chance to get it off.
Old 08-15-2011, 02:34 AM   #9 (permalink)
Mainly just posting to bump and so you know your not forgotten...
But no, I haven't read of anyone doing that, and I have not done it myself.
One last idea. How much of the bolt head is left? Could you get a drill bit and drill a hole crossways through it, then put something through that hole to turn it? Didn't sound like you have enough left, but figured I'd throw the idea out there.
Old 08-15-2011, 12:01 PM   #10 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
You could fill it through the the breather valve hole once you take the breather valve out...
Just make sure you measure the amount that you remove so you can replace it with the same amount.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 08-15-2011, 12:11 PM   #11 (permalink)
BamZipPow's Avatar
You could try this method...
Old 08-15-2011, 10:03 PM   #12 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
1. heat.
2. use a grinder or dremmel and put a groove in the plug. then take an impact screw driver and give it a good smack with a hammer.
Old 08-20-2011, 07:27 PM   #13 (permalink)
fill plug removed
dc98 thanks, I got a friend to take a hammer and prick punch the 17 mm bolt. I finally removed it. Wow there was only 1/2 quart of fluid in there. Never been changed car has over 172,000 miles on it, fill it up with 1.7 quarts of Dexron III.
Old 08-20-2011, 08:06 PM   #14 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
Originally Posted by tony1967 View Post
dc98 thanks, I got a friend to take a hammer and prick punch the 17 mm bolt. I finally removed it. Wow there was only 1/2 quart of fluid in there. Never been changed car has over 172,000 miles on it, fill it up with 1.7 quarts of ATF type IV.
ATF Type-IV??? that's the wrong fluid! it was designed for newer U-series transmissions, not for the A-series.
Sorry bro, but you *should* drain it again and fill it up with something Dexron-III or Mercon-V compatible (dino), or could be something better (pure synthetic or blend) like Mobil1 ATF or Castrol IMV...
Old 08-20-2011, 08:32 PM   #15 (permalink)
Glad you caught it... Didn't know if you had enough room to make it work though ... Get one of those prick punches for your tool box.
When you start hearing things, it's too late.
Check out what fenixus just posted ... it's real easy to get one of these fluids incorrect ... One time I used regular transmission fluid instead of TIV transmission fluid ... big mistake ... Best to consult the owner's manual or just find a Toyota parts department someplace.
