Originally Posted by KoG506
Did you change the sway bar bushing? When does the noise occur? When you go over bumps? is the setting on the RSB correct for both sides?
i got the issue corrected or atlest for now. i checked under the car to day in my spare time and found that one side of the end link bolt, the connect to the sway bar was loose. i have no ideal how but i re tightend it and its good. i hope i forget to make sure it was tight the first time i installed cause i would hate it if it just becomes loose for driving, then i might need a lock washer or thread lock or something. thanks for the help any ways its well appreciated
