I'd say buy it.
Did he keep up on the transmission oil changes as well?
The engine is non-interference, so if you don't change the timing belt and it breaks, there's no risk of major engine damage.
The valve cover oil leaks are messy, but not a big deal. Worst thing about it is that if it's bad enough, it drips onto the exhaust and slowly burns off, giving off some stinky blue smoke. The front cover gasket is a 20 minute job. The rear takes 2-6 hours, depending on how pokey one is. The rear one is usually responsible for the aforementioned burning oil.
Given reasonably good maintenance, they're often good for 300k miles or better.
