Sway Bar Bushings - Replacing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2011, 01:37 PM   #1 (permalink)
View Hobo's Photo Gallery
I have a 1994 Camry LE Sedan 4 cylinder automatic.
I have a clunking in the back when I go over bumps. Mechanic told me it was the sway bar.
I'm going to attempt to replace the bushings myself.
I bought some from Advance today. They come in a pair.
How many do I need? Is it one per side or two per side?
I only bought two total.
Hobo is offline   Reply With Quote
Old 08-16-2011, 01:43 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
there are two sway bar bushings per side and one sway bar end link per side. check the end links for bad spherical joints and play. check the bushings for cracking and bulging.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-16-2011, 04:58 PM   #3 (permalink)
hustle to survive
97toyotacam's Avatar
View 97toyotacam's Photo Gallery
4th Generation
I would take your endlinks off as well to check them individually. I couldn't tell my endlinks were broken until I took them off of the car and started to play with them. Make sure you tighten everything real good and make sure there is no slack.
DIY: Replace your endlinks and rear sway bar
97toyotacam is offline   Reply With Quote
Old 08-16-2011, 10:30 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
exactly. mine looked good too on both cars and wanted to pass on replacing them, then decided to give it a try... what a surprise! all of them were totally loose and even showing some crack of boot at the stud.
here is a video of what you can do with a bad ball stud in faulty sway end link (can't do that with a new ones):
