Bad Distributor, no wait, timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2011, 01:26 PM   #1 (permalink)
View chabunga's Photo Gallery
Angry Bad Distributor, no wait, timing belt
So my son's 95 Camry dies. Gets towed to shop. They say needs new distributor, with towing about $500. Now they say distributor OK was broken wire. They can get it started but it doesn't stay running. Their diagnosis, timing belt, about $600 worst case. Are they guys trying to screw my son, or is this an easy mistake to make?
chabunga is offline   Reply With Quote
Old 08-17-2011, 02:08 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
What do they say is wrong with the timing belt? If it starts at all, the timing belt isn't broken. Off chance it may've skipped teeth, but usually once tooth skipped will run rough, while multiple teeth skipped won't even start. It's dead easy to check timing with a timing light while the engine is cranked -- shouldn't be a matter of guesswork.
I'd say the shop is at least incompetent, if not worse.
Tags
distributor, timing belt
