Camry FAQ page not loading - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2011, 03:52 PM   #1 (permalink)
View twodoorcamry's Photo Gallery
I don't know if it's just on my computer, but the "Camry FAQ READ FIRST DIY" sticky (of the gen 3/4 forum) thread doesnt load for me. It just loads a blank page when I click on it.
Everything else on TN works fine for me.
Could someone in admin please look it up and possible restore this precious page?
Thanks
Dave
twodoorcamry is offline   Reply With Quote
Old 08-17-2011, 04:13 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Reload the page.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 08-17-2011, 04:34 PM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908527
iTrader Score: 59 reviews
No problems here!!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 08-17-2011, 05:29 PM   #4 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
I'm having the same problem, but I could load the DIY section. It seems to be happening more and more recently. I figured it was my setup running maybe an older version of FireFox. So I upgraded to the newer version, 5.01 and it got worse, much worse. I installed all of the latest versions of Flash, Quicktime, and updated all the add ins. Cleared the cache, blah, blah, and still had problems with pages loading.
If I went to the main section everything was fine. Then click on a link, and normally a new window would open, everything seemed to load, the top banner, the side bar, and the footer. But there was no messages, just a blank page. If I reloaded the page, the text would appear maybe 1/2 the time. If I closed out the browser it would work fine, then revert to the same behavior.
I downloaded Google Chrome and installed it. It seemed to solve the problem at first, but then the same thing happened. Click on a link, you get the header, the sidebar, the footer, but no text. Re-load the page and it works maybe one out of three times.
Since this is a recent happening, I went back to an image I made at the first of August. I let Windows update run, but didn't allow any flash updates, nor did I allow Adobe to update. I didn't allow Windows to update the Net Framework either. I uninstalled Quicktime and removed all references in the startup sequence using SysInternals Autoruns that referred to Adobe, Flash, Apple Quicktime and any automatic updates. I left McAfee alone.
Things are much better using the 8/1/11 image. Now the pages load as they should, and only occasionally does the text not display. But the problem has not gone away completely. The image that I restored had FireFox 3.56 which I had used with no problems since it came out in 7/09-12/09.
Unfortunately TN is the only site where this problem occurs. And I'm at a loss as to why. I'll poke around a bit more and see if I can come up with anything conclusive.
Maybe the tech people at TN can offer some suggestions as well.
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is online now   Reply With Quote
Old 08-17-2011, 05:36 PM   #5 (permalink)
View LostSouthernStar's Photo Gallery
Try Internet Explorer or Netscape browsers as these have fewer problems loading pages.
I've never liked FireFox, Chrome or Safari....too slow and outdated.
Hope this helps!
2001 Toyota Camry 2.2L-I4, automatic transmission with 157,000 miles.
LostSouthernStar is offline   Reply With Quote
Old 08-17-2011, 05:54 PM   #6 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Are you running AdBlock or something similar? If not, you should be. This site is so bloody ad-heavy all it takes is one broken ad to screw up page loading.
The Following User Says Thank You to hill8570 For This Useful Post:
ajkalian (08-17-2011)
Old 08-17-2011, 07:28 PM   #7 (permalink)
I wasn't running any sort of ad blocking program. Never crossed my mind.
I installed Adblock Plus 1.3.9 and will see if anything improves.
Good suggestion, thanks.
Old 08-17-2011, 07:42 PM   #8 (permalink)
Well that's the ticket.
I installed AdBlock Plus and the effect was immediate.
All the pages loaded properly and much, much faster than they ever did.
I opened 12 tabs, and every one of them opened fine, all text displayed as it should.
Problem solved.
Many thanks.
