So I'm at the nearby pick n pull salvage yard, searching for a gen4 dogbone motor mount and bracket to reduce my gen3 idle vibration, as well as looking for other things to help improve this car mechanically and aesthetically.
FINALLY I found one!...all others were already stripped when their engines were removed. The rubber looks like crap, but the bracket will atleast save me $32 at the dealer.
So with a ratchet I start unbolting the 2 mounting bolts (14mm?), little by little...almost there...BOOM!!! The engine fell about 12" to the ground. I felt something graze my shoe on the way down. Fortunately I was standing on a tire for leverage and my foot wasn't directly underneath any part of the engine.
So if you're ever in a pick n pull, grabbing a gen4 dogbone motor mount for your gen3 camry, please be sure to check if this is the only motor mount left on the car that's holding up the engine...
