Hi
It is possible that i might be buying a 4th gen(?) camry off my brother, for cheap. It is an SV40/V40 Camry(well actually a vista, but the same thing) It is 1994, and currently is a 3SFE Auto
So far, it looks like i can probably potentially use these boxes:
C52
S53
S54
Now it seems the S54 would be the better one to go for? There is one available locally, which is a S54-04A. It has been pulled from a FWD Toyota Curren ST206
This is the plate from the car in question:
http://images.trademe.co.nz/photoser...57570_full.jpg
The seller of the above box, also has other manual parts available for a little extra: clutch operating gear, the gear lever and control cables/rods and complete handbrake setup
He doesnt have the flywheel or clutch available. What else would i be likely to need?
Also, for flywheel and clutch, so would my motor be a 8 bolt? Being a 94 3SFE? So could i just look out for an 8 bolt flywheel from a 3SGE, or 5SFE? Or what is the story? then what for clutch?
any help/discussion/suggestions appreciated
Thanks
