Installing spolier...Can you.? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2011, 08:27 AM   #1 (permalink)
View astatcamry956's Photo Gallery
3rd Generation Installing spolier...Can you.?
quick question, i have the 95 camry LE V6 these cars didnt come with the spoiler, so can u put one on yourself.? what kinda adjustments would i have to make.?
astatcamry956 is offline   Reply With Quote
Old 08-20-2011, 04:39 PM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908527
iTrader Score: 59 reviews
Of course you can!
The toughest part of installing my spoiler was drilling holes in the trunk!!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 08-20-2011, 05:24 PM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $440905
View rusty9's Photo Gallery
Well maybe yours didnt, but it was an option. Pretty easy to find at the junkyard or ebay, but at the junkyard you'll be able to grab the proper wiring as well so the brake light failure light on the dash doesnt come on.
rusty9 is online now   Reply With Quote
Old 08-20-2011, 05:31 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Not much to it outside of drilling a few holes and hooking up a brake light (if so equipped).
Zembonez is offline   Reply With Quote
Old 08-20-2011, 09:01 PM   #5 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
If you get a spoiler from the bone yard remember to snag the tail light failure sensor from the car you got the spoiler from. if you eliminate the high center brake light you will get a tail light failure warning if you use your sensor. And you want to get rid of the center brake light if you have theLED's in the spoiler. Having the LED's in the spoiler and the center brake light on the rear deck just looks dumb.
Pvt-Public is offline   Reply With Quote
Old 08-20-2011, 09:08 PM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
With the extra weight, the preload on the trunk lift springs might need to be increased. Here's a thread showing how to do it.
BMR is offline   Reply With Quote
Old 08-20-2011, 11:22 PM   #7 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
This is a really neat and easy upgrade. Aside from the tough part of drilling holes in your trunk. If you find yourself a donor car to get the spoiler from, take some extra time to pull the OE wiring harness that powers it. It will pull and plug into your cars OE tailight harness, have fasteners that will lock and route it in a full factory manner to the trunk, and wire it up so it does not set off any dash lights. A nice plug-in, factory like installation.
Guys are right though about fixing the trunk "hold-up" springs, otherwise the thing will have a tendancy to bonk you in the head when your least expecting it.
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 08-20-2011, 11:36 PM   #8 (permalink)
So the Spoiler light, cant you just manually connect the braking wiring that goes to the Reg one to the Spoiler instead...just do some wiring work. Will the dash light be on.?
Old 08-21-2011, 12:00 AM   #9 (permalink)
Domesticon Prime
I dont know the answer to that for sure. Connecting LED's to regular wiring sets off burnt out tailight sensors (dash lights) in my experience. The OE harness for any OE spoiler simply plugs into old points on your original wiring anyway, so why mess around with half ass wiring when you can use the OE stuff that could come with any part yard sourced spoiler, built for your car? This is what I did, and it was great! Plugs, plugged in, fasteners, secured the wiring harness along the whole route, rubber grommets fit into the holes drilled in the bodywork, and wiring lengths were perfect. Why mess with great Toyota engineering, when you can add it to your car for next to nothing as opposed to jury rigging something up? Just IMO.
Domesticon Prime
Old 08-21-2011, 12:54 AM   #10 (permalink)
lol alrighty then, ill post up a thread with pics when i get this done, thx for the help
Old 08-21-2011, 05:48 PM   #11 (permalink)
Pvt-Public's Avatar
Like I said earlier don't forget to get the tail light failure sensor from the donor car or you will get a failure light on the dash. Also get the cover for the center brake light that is where the spoiler plugs in. Then you can remove the center light and still look like the car came with the spoiler.
Old 08-21-2011, 06:14 PM   #12 (permalink)
wait, where is the sensor located at.?
Old 08-21-2011, 06:48 PM   #13 (permalink)
Pvt-Public's Avatar
Drivers side of trunk, behind the carpet, on the backside of a vertical metal support. It is usually blue or yellow in color and about 2.5 or 3 inch square.
Old 08-21-2011, 09:25 PM   #14 (permalink)
Domesticon Prime
Just a note to the OP: LE V-6's did come with spoilers, in fact from what I've seen at the local Pick-n-Pull, just about any model could be optioned with a spoiler, even relatively bare bones 4cyl. examples.
Domesticon Prime
Old 08-21-2011, 09:45 PM   #15 (permalink)
sadly, mine didnt come with it.....
