1998 Camry noisy suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2011, 02:56 AM   #1 (permalink)
al1
View al1's Photo Gallery
Front suspension on my 1998 Camry Sedan has been needing attention for a few months. There were rattles and crunches going over even the smallest of bumps
Over the weekend I replaced shocks, shock mounts and sway bar bushes.
The noises have not stopped. It sounds loose, rattles and crunches, but everything it tight.
Don't want to keep throwing money at it so am here hoping for a diagnosis.
Any ideas?
al1 is offline   Reply With Quote
Old 08-21-2011, 03:41 AM   #2 (permalink)
Tom 2000's Avatar
Gameroom cash: $201300
View Tom 2000's Photo Gallery
I did the same job couple of years ago on my '00 LE. Had the same symptoms you described, but the noise went away.
Did you change the upper and lower spring insulators (rubber pieces)? That's about the only thing I can think of. I changed them on my Camry with the Struts (KYB), Strut Mounts (Toyota Genuine) and Sway Bar bushes (Toyota Genuine).
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is online now   Reply With Quote
Old 08-21-2011, 10:10 AM   #3 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
If the noise is coming from the front suspension, check the inner and outer tie rod ends for play.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 08-21-2011, 02:05 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Sway bar links?
BMR is offline   Reply With Quote
Old 08-21-2011, 02:27 PM   #5 (permalink)
camrtm3's Avatar
Gameroom cash: $102305
View camrtm3's Photo Gallery
The noise will be a mix of your sway bar links and the ball joints. Mine turned out to be the ball joints
2009 EX-L V6 6Spd MT w/Nav (stock for now)
1996 XLE V6 Camry, KSport GT Pro 9/7, TRD RSB, E153 5spd conversion, Gen 3 front end conversion, OBX Headers, Megan Cat Back, TRD M62 Supercharger
Supercharger whine > ex girlfriends whine
http://www.cardomain.com/ride/3329124
camrtm3 is offline   Reply With Quote
