1992 Alternator replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2011, 10:15 AM   #1 (permalink)
View emdz's Photo Gallery
3rd Generation 1992 Alternator replacement
HI all. I have a 1992 camry, v6 3.0 and I'm trying to replace the alternator but I seem to be running into every possible problem. I know its supposed to be easy-ish: pivot bolt, adjusting lock bolt, adjusting bolt. My pivot bolt wont budge (I'm picking up PB Blaster this afternoon) and even when I loosen/remove the lock bolt and adjusting bolt the ac/alt belt stays tight and unmovable. What am I missing? Is there another tensioner? Or will the belt move when/if I get the pivot bolt free? Any advice would be greatly appreciated.
emdz is offline   Reply With Quote
Old 08-21-2011, 02:04 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Yeah, the pivot bolt being tight will keep you from being able to move the alt. When I adjust belt tension, I try to shortcut and barely loosen it. I always have to go back and REALLY loosen it before it'll move.
BMR is offline   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
emdz (08-21-2011)
Old 08-21-2011, 02:57 PM   #3 (permalink)
Thanks for the encouragement. I used PB Blaster, the pivot bolt eventually loosened up and I got the belt off. The lower pulley seems to be the problem after all, its loose and is making a heck of a squealing noise. I'm stuck on how to remedy that situation.
Old 08-21-2011, 03:22 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Is it the pulley directly below the alternator?... that's the AC compressor. Could be the clutch is going bad, or could be the compressor itself. Hard to diagnose without taking it apart further.
Old 08-21-2011, 03:43 PM   #5 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
There is a small idler pulley below the alternator, that one might be making the noise. Some people just take it off (maybe your car doesn't even have it) because it does not do much, if anything.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
