1998 Camry L4 5SFE - Cold Start Rough Idle
Hi Everyone,
I have a 1998 Camry L4 5SFE (150,000 miles) with a couple problems. First, during a cold start my RPM stutters around 500. Next, when I put it in (D)rive, my car goes down the driveway as if it's in (N)eutral and I have to give it some gas before the gear "catches" and I'm good to go.
However, this doesn't happen when I've driven the car at least 5 minutes and start it again. When I do, it idles fine (starts about 1200 RPM then drops down to about 700 RPM).
I've searched the forums about issues closest to my symptoms. I've read everything between a dirty IAC valve to a bad ECT sensor... So I did a full throttle body and IAC cleaning (removed throttle body and IAC, cleaned the butterfly valve and IAC). I even went as far as replacing the ECT sensor and PCV valve and replaced the valve cover gasket.
I'm at a loss here and was hoping to get some insight or get pointed in the right direction from experienced DIYer's here!
Thank you!!!
