Mine is a 5SFE. The EGR Modulator's nipple is what broke (cheap brittle old plastic). Guess I'll plug it and see what she does. Appears to hold alright with epoxy....but I guess now I have a real EGR problem...code keeps coming up (DTC71).
I sprayed some Kroil Oil up in the EGR valve and worked the valve a bit by moving it up and down by hand to unstuck it. Didn't seem to do much.....
On a side note, I wouldn't be surprised it's full of carbon build-up. She has 340k miles on her. AMSOIL Power Foam makes it quite a bit better....still gets the code though. Probably have to take the whole system apart and clean the carbon out.
I'll try plug all the vac lines and see if she runs better. It has poor idling and bad acceleration under 2000 RPM.
I hear ya about this EGR. It's pollution control, not a performance item and at this point, it causes more problems than it's worth.
