Trunk issues?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2011, 06:45 PM   #1 (permalink)
View jaycee1976's Photo Gallery
Trunk issues??
Hello,
i cant seem to open up my trunk. The lever doesn't seem to work. i tried to open it up using the key, but the lock does not even move. How can i pop it open? is there some sort of release valve somewhere? or is the the lock busted?I have a 97 camry xle
jaycee1976 is offline   Reply With Quote
Old 08-22-2011, 07:10 PM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908527
iTrader Score: 59 reviews
Do you have more than one key for it?
If you do try it to open the trunk!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 08-22-2011, 07:16 PM   #3 (permalink)
I tried to use different keys, but no luck. Any other suggestions ...must appreciated.
Old 08-22-2011, 07:47 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
If you pull your back seat down, you can pull the trim piece off the back of your trunk lid and remove the linkage to the lock, and slide it to one side or the other. it should pop open.
Old 08-22-2011, 07:59 PM   #5 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
You probably have a couple of things going on. First the cable has stretched and the lever on the floor won't open the trunk. Here's how I fixed mine when that happened to me.
Trunk doesn't pop up using latch beside the driver seat
The other thing is that once you get the trunk cover off, and the latch unbolted from the trunk, you will see that there is a rod that connects the lock mechanism to the latch mechanism. The rod is held in place by a cheapie plastic clip. Mine was lime green, YMMV on the color. Anyway if this plastic latch cracked, then the rod will come out of the latch easily and now the key in the lock won't unlock the trunk.
Try pushing the lever on the floor to the right towards the center of the car while lifting up on the lever. Fiddling with it should open the trunk. Then follow the instructions on the link and you should be all set. BTW, the first time I did it, I only used one nut, and it wasn't enough, so I had to go back and add another one later. Save yourself some trouble, and use two the first time.
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is online now   Reply With Quote
