fuel coming out vent hose on 2000 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2011, 12:37 PM   #1 (permalink)
View Nortonguy's Photo Gallery
I have this 2000 camry parked on a hill.
I see fuel is dripping out the bottom of the car between the rear wheels so I take a look and there is a fat hose about 1" round that is stuck into a hole in the frame crossmember. It looks like it was put there when the car was new, maybe as an overflow or vent of some sort.
When I loosen up the fuel cap it seems like the drip slows or stops, but when I tighten the cap up, it starts dripping again pretty darn good, made a puddle and the whole area around the car smell really bad.
Has some sort of device failed? It looks like there is some sort of round black plastic thing, some part of the fuel system on the left-rear side of the tank this hose comes out of, lots of other black hoses there too.
Anyone have experience with leaking Camry? Thanks in advance.....
Nortonguy is offline   Reply With Quote
Old 08-23-2011, 10:54 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
a picture?
Old 08-23-2011, 11:21 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
There should be a vent hose on the charcoal canister. I think it's J-shaped. Also a possible problem with fuel filler check valve on top of the tank.
