How do I remove the oil pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2011, 05:06 PM   #1 (permalink)
View smilecow's Photo Gallery
I have a 99 2.2l camry
After I removed the shaft bolt, I tried to remove the shaft of the oil pump but it seems like it' stucked.
could you give me any advice.. can I just hammer that rod thing?
another question is
I forgot to mark the tdc of the camshaft and I removed it..
the rod below the pic shoold be at tdc, right?
and when I install the seal of the camshaft, what size of pipe should I use? id *od?
thank you
smilecow is offline   Reply With Quote
Old 08-23-2011, 05:14 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
Have you check this link? There is a good amount of infomation on it.
DIY: GEN3 Timing Belt + Waterpump + Oil Seal Change - Part 2
I guess you could tap the shaft with a brass hammer until it slip off.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 08-23-2011, 08:32 PM   #3 (permalink)
View Leinad's Photo Gallery
Can you rotate the pump or is it seized?
Once the nut retaining the pulley is removed, the shaft should comme off easily.
Leinad is offline   Reply With Quote
Old 08-23-2011, 08:49 PM   #4 (permalink)
View WaxonWaxStillOn's Photo Gallery
You can probably pry that pulley out a little bit simultaneously from both sides without warping the oil pump. It shouldn't take much. I believe I bought 1.5" pvc for this seal, the smallest piece sold at lowes was 24" long for $2.50 or so (10ft for $4.50.)
WaxonWaxStillOn is offline   Reply With Quote
Old 08-24-2011, 05:29 PM   #5 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
The pulley on the oil pump is held on by a nut. You need to hold the Drive rotor (Rear of pump) and bust the nut off. If you cant find anything to hold it without scratching the rotor, Jam a screw driver in-between the pulley and hold it in place. Then bust the nut loose.
check out the link below.. It shows how to remove that seal
DIY: 5sfe Oil Pump Diagnosis
