95 Camry LE 1MZ-FE Blackstone Oil Analysis - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2011, 06:21 PM   #1 (permalink)
View psilence's Photo Gallery
Hello
I just wanted to post my car's oil analysis up for anyone else that might be looking to compare their own. I've been running Valvoline MaxLife Syn Blend / Bosch Filtech oil filters for the life of the car. Last oil change was the Max Life "Next Gen" syn blend - the green bottle with 50% recycled oil. That was the oil change that was tested here.
Thanks.
psilence is offline   Reply With Quote
The Following User Says Thank You to psilence For This Useful Post:
Yuko (08-24-2011)
Old 08-24-2011, 04:17 PM   #2 (permalink)
View web gem 5's Photo Gallery
nice
web gem 5 is offline   Reply With Quote
Old 08-24-2011, 10:40 PM   #3 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
That's a good amount of Moly. I read that the NextGen version was better than the regular Maxlife with the new SN rating. I feel a little more confident running this oil now. Had stocked some 5W-30 Maxlife Nextgen with two Bosch 3325 filters. (Longer verison of the 3311)
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 08-24-2011, 11:01 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
the report looks good!
yeah, valvoline uses sodium as additive, so it throws off the UOA. I had similar results (114 sampled vs 24 avg) when I mixed only like 1.3qts of Valvoline Synthetic with some Mobil1 FS and Lucas Stabilizer on wife's 5s-fe
Royal Purple (used 5w-30 in past) on the other hand uses tons of Magnesium as oil additive (my V6 in past sampled 978 vs 150 avg)
In a month I will be doing UOA on my V6 after running M1 10w-30 FS HM, will post it too
It's good you share it, it helps to compare results especially for folks who run exactly same oil type.
molybdenum seems a tad high in your UOA, but as I read the Blackstone labs description page correctly, it may be also an oil additive used by manufacturer.
nothing to worry about!
Old 08-25-2011, 11:34 AM   #5 (permalink)
Thanks all
I was very happy to see the engine is doing so well for the mileage it's at. I thought some of the elements were high too, but it looks like all the ones that were higher than usual are used as additives in max life.
Anyway, I hope it helps someone out there using the same oil.
