96 camry 2.2L rough idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2011, 08:25 PM   #1 (permalink)
View mk2mr2's Photo Gallery
Hi. I just changed the radiator, new plugs, cap and rotor today. It's only rough when coming back to idle for a few second. It did die when I came to a complete stop from the highway testing it.
In park, after giving it a little gas it dips to 550-600 a couple of time before idling normal. While driving it it lags and pickup.
I think motor mount. The only new one is the t-bone mount. This weekend I am going to clean the Idle contorl valve to see if it helps. My O2 sensor has been on for over 2 years now. I just never changed it (finally catching up to me?).
Any suggestions?
mk2mr2 is offline   Reply With Quote
Old 08-23-2011, 09:12 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
IAC valve
Old 08-24-2011, 05:30 PM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Originally Posted by fenixus View Post
IAC valve
lol , straight and to the point! Check out these links :
DIY removal & cleaning of IAC
5sfe IAC Removal (lots of pictures)
Old 08-24-2011, 05:50 PM   #4 (permalink)
I cleaned it today and everything is running fine again.
I got the seafoam and deep creep. I cleaned the internal. While I waited I unbolt the tb hose and just sprayed a lot of deep creep a few times while I waited.
I check online but no one had an IAC gasket instock. So I tired this first before I ordered a gasket. Otherwise it would had been an option.
These seafoam works pretty good but expensive Thanks.
Old 08-24-2011, 06:29 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah I was in rush and had no time to type more LOL!
glad you posted the links and happy that cleaning IAC helped the OP
