Changing Differential fluid only with synthetic? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2011, 07:31 AM   #1 (permalink)
View MASTER YOTA's Photo Gallery
Ok one of the few things i was able to do myself on my old camry was drain and refill the transmission fluid. Now that i have a 97 4 cylinder with seperate differential I am considering having mechanic just change the differential fluid with the valvoline maxlifee ( i think it says its synthetic) , and maybe a week or two later i will get under car and drain and refill the transmission fluid.
OK so would having synthetic in differential and dyno in transmission cause any trouble? Is it ok to change differential only, if you are looking to drain and refill transmission within 3 weeks?
MASTER YOTA is offline   Reply With Quote
Old 08-25-2011, 09:12 AM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
I wouldn't worry about it. At 68k miles, I changed out the old ATF with fresh Valvoline Dex/Merc on my Camry; took nearly 10 qts. As for the differential, I replaced it with Valvoline Maxlife ATF (with is a blend I believe) and never had a problem. It is fine to change out just the differential fluid and Maxlife may help the axle seal last longer.
Here's a tip: Remove the filler plug BEFORE the drian plug is removed. I seen and read a few problems with the filler plug jammed while all the fluid has drain out.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 08-25-2011, 11:07 AM   #3 (permalink)
double dose camry
View mail2_jb's Photo Gallery
If you did ATF drain /fill, you can do the differential without any issues. Just follow the DIY here (i did mine couple months back). I used mobile1 atf (used online coupong from advanced auto parts and came aroung $5.50 per qt.
mail2_jb is offline   Reply With Quote
Old 08-25-2011, 12:24 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
I use full synthetics everywhere and no issues on either of cars. you can also mix them with dino (it becomes a blend then), no probs.
