1993 Camry Engine misfire and no power: Help
Please Help. I have a 1993 Camry with 2.2 5S-FE engine that has me stumped. The problem is a misfire at idle and under load, also lack of power. When problem started I changed plugs, wires ( had one bad wire) and distributer cap with rotor, they were due for a change anyway. Engine ran fine for one day then symptoms began again. No trouble codes. Since then this is what I've done.
New coil (old one had crack)
Swaped igniter and MAP sensor with ones pulled from salvage yard.
New Fuel filter
Removed and cleaned Throttle body and Idle control valve
Checked timing
New PCV valve
Checked EGR valve operation
Think I need some fresh ideas to point me in the right direction please!
